查看: 6495|回复: 15
[咨询] 关于净水机的问题
发表于 2010-10-27 12:10 | 显示全部楼层 |阅读模式
由于家里有8个月的小孩子,又对自来水的品质不放心,所以想购买净水设备,由于家里已装修完橱柜里面积也不是很大怕安装麻烦,所以开始想购买近期出现的净水和饮水机一体的净饮机--(没有水桶的,桶是内藏式的。比如美的等厂家生产的净饮机。)
1 o( U$ l' a, |0 ^6 R2 g- X# r/ {
本人对净水设备是门外汉想请各位网友帮忙出个主意且咨询一下:- S6 K" n: P$ x  s1 n
那种净水机值得购买么?时间久了净水机里面会产生二次污染么?
2 w  k4 Z) x# ?  B6 ]: [4 M净水机里面的水放置久了,比如1-2天会有变质或衍生细菌么?
: p* H2 B. J* v9 F% @3 L! j" p8 m我的现有条件怎么样的净水方案才适合我呢?
. K# t! ]5 A0 ~6 _( ]
+ G/ x# [6 h* s+ M非常感谢!
发表于 2010-10-27 13:23 | 显示全部楼层
时间久的话都可能会有二次污染..不过1-2天的情况下可以不用在意
6 h" |1 H( V: V1 w! `' b
6 J# V' f. T3 a2 B8 E% G3 h9 R" w是不是可靠与采用的处理技术有关.3 c, q" k5 e! ~' k6 ^- i
" A: ^  h% ?; }+ K. Z
一般情况下,建议你选择RO纯水机...至于什么矿物质/微量元素一类的,只要小家伙在吃配方奶和普通食物,自来水中的可以完全不必在意..
发表于 2010-10-27 15:31 | 显示全部楼层
Further to your e-mail regarding water filtration system for commercial and residential use, we have further simplified the system as described below. We have done a lot of homework in India and have found interesting information regarding the present RO Systems widely used in the Indian market.  We have discovered, especially in children and senior population that their immune system is compromised due to the use of RO Water at home and when they do go out and drink regular drinking water in the schools, the children get sick very easily.  Based on some of the information available to us, we have discovered that the water rejection rate in the RO Systems is around 60% and therefore, a significant loss of critically needed minerals does affect the immune system and other ailments.  We recognize that some of the mineral deficiency should be resolved through other means, however, the fast-food is a fast growing industry in India with McDonalds to KFC to Domino Pizza, Pizza Hut, too numerous to list, on every block.  Therefore, a combination of minerals lost from the water and eating habits is definitely impacting the situation.  It is my opinion that RO System has done a wonderful job for the last decades, but maybe seeing a decline in the near future as people begin to recognize these issues.
& U9 _1 y) \5 n# Q7 {9 b+ ?: T# [# G
上面一段文字是一个客户写给我的邮件.
" p0 s2 a2 E3 O" u) u. F' b! Z3 F1 z7 u' r
大家可以参考一下.
发表于 2010-10-27 19:47 | 显示全部楼层
希望能够有更多的实际的数据来大家一起讨论一下.
& N5 ^# c, s2 ?) p/ |$ W4 f
; u+ j9 g: n) t, B! @$ L8 m* _! O# d如果真的去过印度的话就会知道...要说那里喝纯水不如自来水...
 楼主| 发表于 2010-10-27 21:24 | 显示全部楼层
谢谢管理员的解答,继续请教--RO纯水机 是选择安装在管道水龙头那里直接出水的好还是RO纯水机和饮水机一体的好呢?RO纯水机维护麻烦么?维护保养费用怎样?再回到第一个问题,超滤的净水和饮水机一体的净饮机--(没有水桶的,桶是内藏式的。比如美的等厂家生产的净饮机。)怎么样?谢谢!
发表于 2010-10-27 22:49 | 显示全部楼层
RO机维护不算太麻烦.国产的机器费用也不高.
5 Q& n& B; k1 V& Q/ @+ b" }6 t9 H) O/ Y5 c
你说的这几种方式并没有确定的答案说哪一种就肯定好..主要还是看自己的喜欢./ m  n! M, [) N- h+ X
4 Y" O$ ?8 F' Q
因为实际上只是样式和外观方面的区别而已.
* i/ {" k$ `3 M+ f8 a% N- W
$ v2 Z* V% D- a
4 b# g- ^. E* e0 ~
9 H9 i+ w" D5 j
 楼主| 发表于 2010-10-28 21:20 | 显示全部楼层
非常感谢管理员的解答。还有问题要咨询,本人在辽宁,看论坛里面有说北方的水质较硬,辽宁的水质也应该比较硬吧?如果安装RO机纯水机有必要在前面再加装个软水机么?再有怎样能知道当地的水质的具体指标呢?谢谢!
发表于 2010-10-29 10:25 | 显示全部楼层
 楼主| 发表于 2010-10-29 21:33 | 显示全部楼层
回复 zhangjianfang18 的帖子
: w7 c( ~7 i% X
7 D- [  i, O% U你怎么只是呲牙不解答啊?
. N  l' \/ m$ c1 V
 楼主| 发表于 2010-10-29 21:48 | 显示全部楼层
发表于 2010-10-29 23:03 | 显示全部楼层
纯水机处理后就是软水了,除非你需要生活用水的处理
发表于 2010-10-31 14:12 | 显示全部楼层
纯水机出水就直饮了,已经可以去除大部分硬度了,不需要软水机了。如果需要全屋软水,比方说洗衣服,淋浴等要软水,可以装软水机的!
 楼主| 发表于 2010-10-31 16:42 | 显示全部楼层
发表于 2010-12-14 16:08 | 显示全部楼层
加装软水机可以改善全屋生活用水品质,也可以保护RO机,经济充许的话,装比不装好。4 z. q' j+ ]" w( C6 A; m; @6 A
当然,如果仅仅是喝水,不装软水机是没有问题的,只是换滤芯及膜的频率要快一些。
发表于 2011-2-10 20:59 | 显示全部楼层
建议纯水机前面加软水机性价比还是高不少的
发表于 2011-3-3 13:50 | 显示全部楼层
支持版主的看点
GMT+8, 2026-11-20 21:58 , Processed in 0.054546 second(s), 4 queries , Redis On.
