查看: 3121|回复: 3
有没有关于余氯发生器的作用,比较权威的说法
发表于 2012-11-17 12:37 | 显示全部楼层 |阅读模式
我总感觉# c1 z1 _$ i5 c
7 W; d& W1 q6 d
如果宣传是保护树脂。  o" G% R; t: t: E
, p2 h2 d6 R7 k% f4 r1 ~4 \
这点很牵强。氯气不是会破坏树脂颗粒么。。。
9 D1 l8 q; k# V5 h" v+ Z2 B7 `5 s' _# L; ]% g
发表于 2012-11-17 12:53 | 显示全部楼层
回帖奖励 +1 威望
汗。直接只宣传保护树脂肯定是自己打耳光啊……
7 Y3 h8 m' v* I. ]( Y7 ~2 @' n4 \: l5 R/ h
没看具体的介绍,感觉可能是说去除了微生物和部分有机物可以在一定程度上保护树脂吧
 楼主| 发表于 2012-11-19 11:04 | 显示全部楼层
The main reason for the chlorine generator is the plumbing code in some Europe countries state that the softener must generate some chlorine in the softener system to disinfect it.  The code does not really say how much or how long.
! S3 k1 G: ^5 }$ L7 C4 Y* U' X. r/ I$ j8 }# v  K7 y) ]* z& ]
4 t' |% Z, {; J- ?; C) @) V; e" UChlorine will be bad for the resin but it can withstand some chlorine and the amount from the generator is not too much.  But overall, it would hurt the resin but we don't really know how much.
# R5 `+ T# e: f5 @+ C
0 l  e2 d7 E( f" ~外国友人的回复。  A+ R1 R0 K- b3 e' T
1 G9 Y# A! w' h; z" E
发表于 2012-11-22 12:22 | 显示全部楼层
是的。欧洲有很多地方要求软水机必须配电解装置,主要是来对树脂床进行消毒。以免藻类和微生物生长
GMT+8, 2026-11-20 21:30 , Processed in 0.072180 second(s), 6 queries , Redis On.
