楼主 |
发表于 2014-1-13 13:52
显示全部楼层
AHAM关于室内空气净化器认证
关于室内空气净化器产品。
2 n$ `- ?0 G. ?4 a$ h9 K5 Z8 h; S' {! u
3 _, c2 W) ~0 x' y: b
The AHAM Verification Program for Portable Electric Room Air Cleaners
4 Q1 k ~/ z; _- } UAHAM is an organization that verifies the testing results of home appliances such as room air conditioners, dehumidifiers and, of course, room air cleaners.1 }9 S* t+ K$ m7 b$ w: q" I$ S
, z. w) [) M6 k/ kSince 1967, we've used outside labs to test products, and today you'll find AHAM verified ratings on a variety of appliances. This makes comparing products easier for you.3 H1 y4 p+ f) }. a4 S; ~
: l3 A) W2 _" z
All of the manufacturers listed in this directory voluntarily participate in the AHAM certification program for room air cleaners. This standardized measurement system known as the Clean Air Delivery Rate, or CADR - determines how well an air cleaner reduces pollutants such as tobacco smoke, dust and pollen.5 D1 E9 F8 |7 ~; u+ M
" q+ {7 S/ X0 z4 T& v
From air cleaner to air cleaner, compare the CADR numbers listed next to each model number. First, look at suggested room size. Then refer to the tobacco smoke, dust and pollen CADR numbers. The higher the numbers, the faster the unit filters the pollutants out of the air. If from one unit to the other the ratings are the same, their air filtering performance is similar.0 y0 v ~5 Q. B2 S8 G
3 c! F5 e1 ?2 E% rThe AHAM Verification Program for Portable Electric Room Air Cleaners- K0 X0 P2 v) J/ ^) V% [' q; k0 K$ o
The Portable Electric Room Air Cleaner Verification Program provides assurance to the public, through presence of the AHAM Verification Seal, that manufacturers' claimed ratings of Clean Air Delivery Rate (CADR) have been independently verified in accordance with ANSI/AHAM Standard AC-1, "Method for Measuring Performance of Portable Household Electric Room Air Cleaners.2 B& n3 T- E1 y
& ?+ l" i4 u: l/ YIn addition, all ENERGY STAR® models shown in this directory are required to meet the requirements of both AHAM and the ENERGY STAR® program verification testing.
+ Q3 a4 C! c7 f6 z- m: J% j
" i3 k1 `/ s4 F6 tUnder the terms of the Program, manufacturers certify the CADR of a portable electric room air cleaner. An independent laboratory verifies the performance of random samples taken from factory, warehouse and dealer showrooms.$ u% w, g: I2 r1 |
! W) h6 V- B6 v3 }3 D, qParticipation in the Program is voluntary and is open to all manufacturers and firms who market private brand models. As program sponsor and verifying authority, AHAM retains a laboratory (Intertek) to administer testing of sample units and to verify manufacturers' claimed ratings. ?/ E1 ]2 Y% E! `; Y g* P) s8 z
' F/ y% P$ F3 l" O- q6 F
Program Scope
5 X% r/ d+ d/ k/ M) I: k! ^ANSI/AHAM Standard AC-1 applies to portable electric room air cleaners that remove particulate matter from the air and that have CADR ratings within the ranges noted below:
- X* x* z9 Z& j. N8 N1 D2 V
, X; k: Q. S1 FTobacco Smoke 10 to 450 CADR
% P, f4 O, s K# P, C5 JDust 10 to 400 CADR8 G/ _: P. A2 `) c) A8 [
Pollen 25 to 450 CADR. D) ^) z: P7 ?; e3 o0 M) Q
8 g6 e% E) u+ @) P& Y2 I& z5 {
Room Size Calculation
+ W7 H J0 J, g3 Q6 m# rRoom size is calculated using the following formula:
# ?2 Q6 S- I6 ]& R7 {! B/ f3 |
1 }% v0 X1 k1 d8 yRoom Square Feet = Smoke CADR value x 1.55 (or Room Square Meters = Smoke CADR value x 0.144)8 f# B0 F1 {: N- _6 ]5 G
" }0 H' D0 r+ d } U5 a
This formula is based on the CADR requirement to remove 80% of smoke particles, assuming one room air exchange per hour. Further information on this calculation can be obtained from AHAM.; a. |- p8 s3 o9 V, N
9 R% F: j* N4 ^ K% fENERGY STAR® Verification
2 E+ R) w: ^3 Y9 n# x* KThe US Environmental Protection Agency (EPA) requires third-party verification that an air cleaner bearing the ENERGY STAR® label meets the requirements for dust CADR per watt and standby power. AHAM is an EPA recognized verification administrator providing verification testing for ENERGY STAR® models. All ENERGY STAR® models shown in this directory are required to meet the requirements of both AHAM and ENERGY STAR® verification testing./ O9 M- ?3 i3 H; `) m# x! x
: h* ]# `, W% _& l' zVerification Mark B, ~9 j- j0 h# ~+ X8 O( [
The AHAM Portable Electric Room Air Cleaner Verification Mark is issued by AHAM to all manufacturers and private brand sellers of portable electric room air cleaners who are Licensees in the Program. Under terms of the Program, the manufacturer certifies that the CADR of all portable electric room air cleaners bearing this Mark are determined and accurately stated in accordance with the requirements of ANSI/AHAM Standard AC-1. The Verification Mark is required on all packaging of certified portable electric room air cleaners. Additionally, Program terms require that manufacturers display only CADR values for tobacco smoke, dust and pollen within the verification Mark. The Mark cannot imply verification of any other feature or performance factor. The use of ENERGY STAR® mark is administered by the EPA and the Department of Energy (DOE). While testing as part of the AHAM program does verify this rating, AHAM does not control use of the ENERGY STAR® mark.# h9 k2 l4 B3 U$ p
* |9 a8 U" w, M: M4 Q
Directory3 G& O% k; t6 p( w1 a
AHAM's Directory of Certified Portable Electric Room Air Cleaners lists current program models for each participating Licensee in the Program. The directory may include room air cleaner models that were produced during a previous directory period, but which have no scheduled production during the current period. 2 b; ~* j' T, b# W$ G, \# J
" X* W; j! P$ Y7 Z3 Z2 m1 c6 D
Inquiries and Comments
) _1 P; i) s9 wComments or questions on AHAM's Portable Electric Room Air Cleaner Verification Program should be directed to AHAM.
4 o6 a7 S7 v- G9 c. @ |& a
! u% W4 }% _/ o% Q! g/ f1 w& Z6 m. z& @: B) y% @; ~4 z
0 ~2 F9 \' `% b* z E; C
. `4 \/ H5 p- N2 o# z- H" K |
